Forum >Problem with THE LCD SHIELD
userHead Account cancelled 2019-03-03 03:25:17 9268 Views1 Replies
Hi there.
I've just purchased the lcd shield from dfrobot. Now that I've finished the programming I'm ready to connect some inputs. I need to use digital pins 10-12, 5v and ground on my arduino uno. I'm sure I have to solder the connection on the lcd shield, but I want to make sure before applying the heat.
Any suggestion would be appreciated
Thanks in advance
2019-03-13 01:04:23 You can use the pins on the LCD shield directly when plugged on Arduino, could you specify what's your concern about the usage? userHeadPic robert.chen
