Forum >RPLidar mounting screw size
RoboticsGeneral
userHead Account cancelled 2019-03-03 18:28:13 5420 Views2 Replies
Hello, I purchased your RPLidar unit some time back and, although it works fine, I need to mount it. I tried several small metric screws but none fit into the mounting post holes.
What size screws do I need? I saw an earlier post somewhere asking this same question and the answer was give to refer to the ld108_slamtec_rplidar_datasheet. This datasheet provides spacing information but nothing about screw hole size.
Thanks, David
2019-03-22 21:21:43
butt.clips wrote:
Sun Mar 03, 2019 2:28 am
Hello, I purchased your RPLidar unit some time back and, although it works fine vidmate, I need to mount it. I tried several small metric screws but none fit into the mounting post holes.
Thanks, David
Nice article thanks for sharing……
userHeadPic arinfrolova1990
2019-03-13 01:22:55 The mounting holes should be the metric M3 screws. userHeadPic robert.chen
