Forum >RLY 8 Unable to connect
userHead ddhom 2019-03-23 09:53:12 819 Views2 Replies
Unable to connect to RLY 8 using Ethernet_Com_Control.exe and direct connection, IE no switch. Allowed over two hours to connect. Able to ping using command prompt. PC has static ip as instructed by manual. When attempting thru putty, I receive "connection refused". Unable to edit the Ethernet_Com_controls except for baud rate.. Any ideas?
2019-03-30 03:32:02 The intent of the project was to use the rly 8 over the network. The PC that will control it will be 280 feet from the RLY 8. The project requires that personnel not have to leave the control room to diagnose a problem, The product needs to use PoE. userHeadPic ddhom
2019-03-27 19:49:12 How about just use the COM port to control it through serial? userHeadPic robert.chen
