Forum >Ref: Mega Multi IO Shield for Arduino Mega / DUE
userHead paul2d3d 2019-04-25 07:12:37 5447 Views2 Replies
I have purchased the above board and am now planning to buy the following boards, I DO NOT WISH TO ORDER THE WRONG BOARDS THAT ARE NOT COMPATIBLE WITH THE Mega Multi IO Shield for Arduino Mega / DUE. For Robot application
Please look at the list below and confirm if the boards are compatible.
If wrong WHICH boards would you recommend
1. Bluno Mega 2560 - An Arduino Mega 2560 with Bluetooth 4.0
OR (which ?)
Arduino DUE - An Arduino Microcontroller Board
2. Gravity: 4 Channel Relay Shield for Arduino
3. Quad DC Motor Driver Shield for Arduino
4. Gravity: GPIO Shield for Arduino
5. Gravity: I/O Expansion Shield for Pyboard
6. Xbee Shield for Arduino
Thanks for your help
Paul
2019-05-23 15:18:05 Thanks for your help
Paul
userHeadPic paul2d3d
2019-05-17 22:52:44 I'm confused about your demands, you want buy these products which is compatible with MEGA 2560?
2, 3, 6 can be compated. If you want to use IO expansion, pls refer to this links:https://www.dfrobot.com/product-1009.html?search=IO or https://www.dfrobot.com/product-560.htm ... ega&page=2
userHeadPic techsupport
