Forum >question about the ir sensor camera sen0158
Hi, as I seen this is the ir camera of the wiimote.
I found many ir cameras on wiimotes with different pinount and behavior
The specs says 0..3m range, but, which dot size at 3m it detects? 1cm diameter more/less?
I found wiimote cameras that detects 1cm dot diameter at 4meters, and those are hard to find.
I would like to know if this sensor meet my requirements, and how much calibrated/tested they came.
I have a project with wiimote cameras and is difficult to me to find replacement due to the different behavior i found on the many versions available.
thank's in advance
Juan
thank's in advance
Juan
2019-05-22 13:56:52 ok, thanks
i bought 3, will wait to receive then, then test and will post my results.
Juan
jio
Juan
2019-05-17 23:20:22 It just one part of Wiimote, the largest range is 3m, I don't think it's accurate enough..
techsupport
