Forum >SEN0220 - calibration
userHead Account cancelled 2019-05-02 05:53:10 1018 Views0 Replies
I have the serial version of this sensor and I'd like to know how to calibrate it. I see there are serial commands for "zero" and "span", but doubt it would be wise to use those, since I don't have appropriate atmospheres to put the sensor in.
I read that I should simply place it outdoors for several hours and it will self-calibrate. Is this correct? We're monitoring an office environment and would like to know the readings are within spec.
Thanks!
