Forum >DFplayer Does Not Initialize Consistently
About 25% of the time, after applying power (~4.8V), a short gnd. pulse (push button) on pin IO2 does NOT play the next track. It stays playing track 1. Both GND pins are connected. All non-essential pins are left open (rx,tx dac adkey usb, busy, etc.) Should some of them be pulled to ground? Any other thoughts?
2019-05-08 18:37:14 Thanks for your fast response. The problem still exists. If I am able to fix it, I will report here. Thanks again. BTW, it is a very nice little product. Well done.
wingman2
