Forum >TEL0047
TEL0047
userHead Account cancelled 2019-05-07 06:00:42 2868 Views1 Replies
Hi all,
I buy a wifi V2.2 module and I'm trying to use with an arduino mega 2560 but, following the wiki instruction, I cannot get anything from it using AT or AT+Ws command. Why?
thanks
paolo
2019-05-18 01:33:16 Did you set the "USB/Arduino" Switch to the USB side to enable PC com port to send AT command to WIFI shield directly, and set the "Run/Prog" Switch to RUN side? userHeadPic techsupport
