Forum >DFPlayer Errors -- HELP PLEASE!
userHead Account cancelled 2019-06-01 12:23:38 2363 Views1 Replies
Hello!
I'm having various errors with the DFPlayer mini module.
First, for some reason,
myDFPlayer.play(1);
plays the third file in the sd card. The files are within folders(named '0001-(name)' and so on), and within each folder, there are two .mp3 files (named '0001-(name)' and '0002-(name)'). For some reason, the previous line plays SD: /0002-(name)/0001-name.
Second,
myDFPlayer.playFolder(1, 1);
always ends in "DFPlayer Error:Cannot Find File"
And third, I want to know the reason for the Time Out. For some reason, my code ends in time out all of a sudden.
I found no explanation online for these issues.
All of this was tested using the "GetStarted" code, albeit modifying just a line or two, depending on what to test. If something is not clear, ask and I'll provide more of the code.
Thank you very much!
