Forum >Cant read anything from Winsen ZH03b sensor
userHead Account cancelled 2019-06-06 01:11:40 3234 Views1 Replies
Im trying to use code found on this website for this sensor, but I keep getting 0 for values for PM1, PM2.5 and PM10. The code I am using is:
//*Abstract: Read value of PM1,PM2.5 and PM10 of air quality
//*Product Link: http://www.dfrobot.com.cn/goods-1113.html
//8
//*The RX pin on the sensor connects to pin 10 on the Arduino
//*The TX pin on the sensor connects to pin 11 on the Arduino
//*Version:V3.1
//*Author:Zuyang @ HUST
//*Date:March.25.2016
#include <Arduino.h>
#include <SoftwareSerial.h>
#define LENG 31 //0x42 + 31 bytes equal to 32 bytes
unsigned char buf[LENG];
int PM01Value=0; //define PM1.0 value of the air detector module
int PM2_5Value=0; //define PM2.5 value of the air detector module
int PM10Value=0; //define PM10 value of the air detector module
SoftwareSerial PMSerial(10, 11); // RX, TX
PMSerial.begin(9600);
PMSerial.setTimeout(1500);
Serial.begin(9600);
if(PMSerial.find(0x42)){
PMSerial.readBytes(buf,LENG);
if(buf[0] == 0x4d){
if(checkValue(buf,LENG)){
PM01Value=transmitPM01(buf); //count PM1.0 value of the air detector module
PM2_5Value=transmitPM2_5(buf);//count PM2.5 value of the air detector module
PM10Value=transmitPM10(buf); //count PM10 value of the air detector module
static unsigned long OledTimer=millis();
if (millis() - OledTimer >=1000)
OledTimer=millis();
Serial.print("PM1.0: ");
Serial.print(PM01Value);
Serial.println(" ug/m3");
Serial.print("PM2.5: ");
Serial.print(PM2_5Value);
Serial.print("PM1 0: ");
Serial.print(PM10Value);
Serial.println();
char checkValue(unsigned char *thebuf, char leng)
char receiveflag=0;
int receiveSum=0;
for(int i=0; i<(leng-2); i++){
receiveSum=receiveSum+thebuf[i];
receiveSum=receiveSum + 0x42;
if(receiveSum == ((thebuf[leng-2]<<8)+thebuf[leng-1])) //check the serial data
receiveSum = 0;
receiveflag = 1;
return receiveflag;
int transmitPM01(unsigned char *thebuf)
int PM01Val;
PM01Val=((thebuf[3]<<8) + thebuf[4]); //count PM1.0 value of the air detector module
return PM01Val;
//transmit PM Value to PC
int transmitPM2_5(unsigned char *thebuf)
int PM2_5Val;
PM2_5Val=((thebuf[5]<<8) + thebuf[6]);//count PM2.5 value of the air detector module
return PM2_5Val;
int transmitPM10(unsigned char *thebuf)
int PM10Val;
PM10Val=((thebuf[7]<<8) + thebuf[8]); //count PM10 value of the air detector module
return PM10Val;
I dont have any adapter so I wired 5V, GND, and Tx Rx directly to Arduino mega. Ive tried both hardware and software serial but keep getting 0. The datasheet of used sensor:
https://www.winsen-sensor.com/d/files/a ... e-v2_0.pdf
Ive even tried to change bytes that are read but with no success. Any idea whats wrong?
