Forum >MIND+ 1.56 Release micro:bit problem
Mind+General
userHead anonymous 2019-07-13 00:01:43 7627 Views1 Replies
All of a sudden the micro:bit button press HAT blocks are not working in the last release (v1.56)
In the ONLINE mode, the individual detection block (is button A pressed?) will work, but the HAT block does not detect the press and execute code under it.
Same code loaded in the OFFLINE mode will work OK.
micro:bit is connected, driver loaded, and other functions are working.
I reloaded version 1.53, and all the blocks are working perfectly!
2019-07-25 23:07:21 two weeks and no reply at all !!!!! userHeadPic anonymous
