Forum >MIND+ micro:bit COMPASS problem
Mind+General
userHead anonymous 2019-07-13 00:11:00 8064 Views2 Replies
Both 1.53 and 1.56 releases display compass reading of 90 and 270 only. No other direction is displayed.
2019-07-24 05:25:03 COMPASS works OK when micro:bit is used alone.
However I am using the micro:bit as mounted on your DFROBOT Maqueen Car.
There, maybe because of the orientation of the micro:bit, the Compass readings are way off.
userHeadPic anonymous
