Forum >Beetle-to-Beetle Wireless Programming Doesn't Work
Bluno General Arduino
userHead Grande Andrew 2015-12-29 14:54:42 3618 Views1 Replies
I have 2 Bluno Beetles and am trying to follow instructions for remote programming.
https://wiki.dfrobot.com/Bluno_SKU_DFR0267
another one from the Bluno Beetle Dev Workshop book, which is basically the same info
Few sanity checks:
I've updated both beetles to firmware v1.94
Set one to role CENTRAL and connected to the Mac.
Set another to PERIPHERAL and provided a wall plug power (no computer/usb connection)
They do connect on power-up and link led is on on both.
When trying to program, I'm getting the avrdude:
Code: Select allstk500_recv(): programmer is not responding
error. Before this message, the central beetle flashes the tx/rx leds and I can confirm the peripheral one also communicates (tx/rx leds are flashing). Then it all fails.
Please let me know if I misunderstood the concept (use Central to program the remote beetle).
2015-12-31 00:56:12 Hello,
This Arduino error indicates that the serial was occupied, so please remove the wires connected with D0,1 if it did.
Btw, have you use AT+BLUNODEBUG=OFF to turn off the feature of USB debug?
userHeadPic Leff
