Forum >Persistent data stroage in BLUNO
Can I store data in BLUNO persistently?
The stored data should be readable after power cycle.
2014-07-16 21:52:32 No prob! ;D
If you run out of memory consider the SD card module. But if you keep it short, should not be needed.
Jose
2014-07-14 23:48:44 Hi!
The chip has some small space to store stuff on it, will be maintained after power cycle unless it is erased by code.
http://arduino.cc/en/Reference/EEPROM
It's not much, but usually is quite enough for what its worth. A phone number should not be a problem.
Cheers!
Jose
Cheers!
2014-07-14 23:42:20 Hi Visualxl,
I mean the data can be changed during execution.
I will register/unregister phone number during execution and the resulting data should be maintained after power cycle.
Jung-Ho Park
2014-07-14 20:35:10 Whatever sketch you upload, the variables (data) will be stored persistently until you upload another sketch.
visualxl
