Forum >DFROBOT SEN0192 configuration
userHead rogsykora 2019-09-28 10:28:42 1788 Views2 Replies
I am planning to mount this sensor,DFROBOT SEN0192, in a box, my question is:
I do not want to mount the sensor so the sensor side is toward the inside of the box.
The is a potentiometer to control distance and 2 led's are mounted on the sensor side, that would need to be facing the side of the box(when mounted). Also the device would need to be unmounted to adjust the potentiometer.
Would there be a problem with removing them and mounting them on the other side of the pcb?
2019-09-29 08:58:57 After further checkout of this device I find the configuration, of the sense indicator on the sensing side of the sensor, helpful to checkout the area that activates the sensor and make adjustments by one person. If this device activates the same after it is packaged in an enclosure, it will be great! userHeadPic rogsykora
