Forum >Problem with USB
Problem with USB
userHead shadow100 2016-04-24 13:34:49 1540 Views3 Replies
I bought a DFRduino UNO and i worked well with him.
Today i got a problem. The usb stopped working.
When i plug in the L light and the on light turn on, but i cant select serial port in the arduino IDE and my pc cant find the dfrduino. I tried dfrduino of my friends and they worked well in my pc.
I think my usb is broken, it is easy to repair?
Thank you, sorry for my english
2016-04-26 02:09:47 Hi shadow100,
If the some components on board get very hot once connected USB cable, you also have to replace that defective components.
userHeadPic Leff
2016-04-26 01:09:47 Hi,
No, i tried my friends dfrduinos in my pc and it works. My dfrduino didnt work in my friends pcs.
Thank you for your reply, but i think i found the problem. My dfrduino usb port probably burned, so i think replacing the usb port will fix the problem ;)
userHeadPic shadow100
2016-04-25 19:57:41
shadow100 wrote:Hi,
hello there, thanks for the post, sorry to hear you are having issues.
let me repeat the problem back to you to make sure i understand it correctly:
you have used the dfrduino uno with your pc and it worked, and then suddenly stopped
you can't select a serial port and your pc doesnt detect it anymore
you have tried it on your friends pc and it worked?
several things to try if you havent already:
- try a different usb cable
- try an alternative usb port
- uninstall and reinstall arduino drivers
if the problem persists reply here and we can help further
hope this helps
userHeadPic Maht
