Forum >dfrduino FIO uploading code problem
userHead Account cancelled 2016-07-23 08:05:45 1578 Views1 Replies
Hi guys! i bought dfrduino FIO last few weeks ago and when i uploading a code i think that the FIO not communicated with the FTDI Basic. What is the problem in uploading the code? i am just uploading blinking sample codes from arduino
2016-07-25 22:44:12 Hi Cezar,
Did you connect Xbee module to the board when you uploaded the code? The XBee socket and FTDI connection dfrobot on the same TX/RX pins of the ATmega328. You will need to remove the XBee module while reprogramming over serial.
If not, could you provide me a picture about your connection diagram? Especially the place of connecting with FTDI.
userHeadPic Wendy.Hu
