Forum >Cannot send message?
userHead JJ 2015-01-20 07:44:13 1744 Views1 Replies
Hi all,
I unable send out message ???
RDY
+CFUN: 1
+CPIN: READY
GPS Ready
Call Ready
AT
OK
AT+CSQ
AT
OK
AT+CSQ=?
+CSQ: (0-31,99),(0-7,99)
OK
AT+CSQ
+CSQ: 14,0
OK
AT
OK
at+CMGF=1
OK
AT+CMGS="0xxxx093"
> HI.
ERROR
AT+CSQ
+CSQ: 14,0
OK
AT+CSQ=?
OK
AT+CMGS="01xxxx93"
> HI.
ERROR
May i ask what is the causes fro it? Is it possible causes by power supply as they powered by 350mA/7.5V
The code I used as wrote in Wiki
//Init the driver pins for GSM function
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
digitalWrite(5,HIGH);
delay(1500);
digitalWrite(5,LOW);
// Use these commands instead of the hardware switch 'UART select' in order to enable each mode
// If you want to use both GMS and GPS. enable the required one in your code and disable the other one for each access.
digitalWrite(3,LOW);//enable GSM TX?RX
digitalWrite(4,HIGH);//disable GPS TX?RX
Thanks reply.=)
JJ
2015-01-29 12:27:27 This part of code say nothing to me, but i had a similar problem. Mine was that i ran out of credit. You can also try to change your number to international format +43XXXXXXXXXX. or you forgot to send the ctrl+z character aofer the "hi." add this line after the "hi." "GSM.println((char)26);" userHeadPic cry4brk
