Forum >Beetle BLE - Low power mode
Bluno General Arduino
userHead leonismaiel 2020-03-25 09:56:17 4363 Views5 Replies
Hello, I have bought the Beetle BLE : https://www.dfrobot.com/product-1259.html
I am using it battery powered so it has to use as less power as possible. I have read that BLE 4.1 has got a low power mode : https://wiki.dfrobot.com/DFRobot_Blueto ... e#target_5
it says AT+LOWPOWER=ON enables it. Does the Beetle have BLE 4.1? If not how can i upgrade it. I have tried the Bluno Firmware Software but how do I know it worked?
AT+LOWPOWER=ON gives ERROR CMD.
2020-03-26 22:26:15 its Version 1.97
And my OS is Windows 10 64bit
userHeadPic leonismaiel
2020-03-25 14:25:28 How can I use AT+LOWPOWER=ON with my Beetle? userHeadPic leonismaiel
2020-03-25 09:58:55 Updating it with the Bluno2 Firmware gives the following error:
Code: Select all
Exception in thread Thread-1:
Traceback (most recent call last):
File "threading.pyo", line 801, in __bootstrap_inner
File "bluno2v0.3.py", line 234, in run
TypeError: UpgradeThread.percentSignal[object, object, object] signal has 3 argument(s) but 1 provided
