Forum >IO Expansion HAT x1 for Raspberry PI, PWM not working
RoboticsGeneral
userHead anonymous 2020-03-28 09:01:29 3024 Views1 Replies
I have a Raspberry Pi 3B+.
I enable pwm in /boot/config.txt
dtoverlay=pwm-2chan
When I use PWM in the code I can see the changes in the /sys/class/pwm/pwmchip0 folder (period, duty_cycle, enable), but the PWM output does not change.
Do I need to install/configure extra stuff for the PWM on the hat to work?
