Forum >Problem with DFRobot_SIMclient
Easy IoT General
userHead andries.arenek 2020-03-29 01:39:35 5959 Views4 Replies
Trying to compile project that references DFRobot_SIM7000, which in turn references DFRobot_SIM.
Getting compile time errors:
DFRobot_SIMcore.cpp:7:17: error: invalid conversion from 'Stream*' to 'SoftwareSerial*' [-fpermissive]
Code used (using esp8266):
#include <Wire.h>
#include <DFRobot_SIM7000.h>
#define PIN_TX 7
#define PIN_RX 8
SoftwareSerial mySerial;
DFRobot_SIM7000 sim7000;
void setup(){
Serial.begin(115200);
mySerial.begin(115200, PIN_RX, PIN_TX, SWSERIAL_8N1, false); // Default SIM7000 shield baud rate
while(!Serial);
Serial.println("BEFORE begin()");
sim7000.begin(mySerial);
Serial.println("AFTER begin()");
Serial.println("BEFORE turnON()");
sim7000.turnON();
Serial.println("AFTER turnON()");
void loop(){
Serial.println("INSIDE LOOP");
2020-03-31 22:26:08 Thank you. I've updated my code, but it is stuck at "BEFORE turnOn()", i.e. busy turning on.
Code: Select all
#include <Wire.h>
#define PIN_TX 7
#define PIN_RX 8
SoftwareSerial mySerial (PIN_RX, PIN_TX);
void setup(){
mySerial.begin(9600);
while(!Serial);
sim7000.turnON();
void loop(){
userHeadPic andries.arenek
