Forum >Huskylens with microbit, using makecode
HUSKYLENSGeneral
userHead Account cancelled 2020-04-17 05:40:16 3796 Views2 Replies
I have a problem using my huskylens with micro:bit. I followed the instructions in wiki, I used the same code (https://wiki.dfrobot.com/HUSKYLENS_V1.0 ... #target_36, makecode environment), but on my micro:bit there is just a blinking X. I think it is the "initialize until" process.
The huskylens works.
The only difference is the cable because I have a Tembusu board (https://cdn.shopify.com/s/files/1/0230/ ... 1537251727) and I used the standard cable in I2C1.
Have you idea what can I test, change or modify?
Thanks a lot.
