Forum >FireBeetle LoRa 868MHz problem
Hello, I'm new electronic make. I recently bought FireBeetle LoRa 868MHz connected to FireBeetle Board - ESP32.
I soldered the pins suggested at: https://wiki.dfrobot.com/FireBeetle_Cov ... KU_TEL0125
then I copy the code in the same link to arduino program but when I click on verify, I receive this error:
exit status 1
call to 'bool DFRobot_LoRa::init(uint8_t, uint8_t)' uses the default argument for parameter 1, which is not yet defined
what I have to do?
exit status 1
what I have to do?
2020-05-29 01:26:01
kelleyhicks1973
the questions myself too, no experiences?tschlatter91 wrote: ↑Thu May 07, 2020 7:54 pmHi TelltheBell
Were you able to solve the issue? I downloaded the library from the Wiki two days ago and still get the same error like you did about the missing definition of D2 and D4 (i.e. the defaults for NSS_PIN and RESET_PIN).
Any help is appreciated:-)
Cheers
Tobi
2020-05-08 11:54:15 Hi Sambo
Cheers
Tobi
tschlatter91
Cheers
Tobi
