Forum >Ozone i2c sensor DFROBOOT - Read value in Python on raspberry PI
userHead anonymous 2020-05-10 06:40:11 3801 Views7 Replies
Hi everyone,
I should acquire the data in PPM with the OZONE O3 I2C DFROBBOT sensor, urgently read the values on my raspberry:
Here is the OZONE sensor (0-10 ppm)
https://wiki.dfrobot.com/Gravity_IIC_Oz ... 1#target_6
I can't find any simple basic script to read the PPM values from the I2C digital OZONE sensor directly in python :ugeek: .
Only the Arduino code language I found, I urgently need your help with Python data reading language.
I repeat is an I2C bus digital OZONE sensor compatible with raspberry and python.
If you can help, it's urgent.
Bass34
2021-01-18 18:37:54 https://github.com/DFRobot/DFRobot_Ozon ... aspberrypi
Our Arduino code and the Python code used on the Raspberry Pi are together
userHeadPic 347945801
2021-01-16 06:13:29 Hello,
I just purchased this Ozone sensor and was hoping to use it with a Raspberry Pi 4. Has this library been created for Python? I ask because the product description says it will work with the Raspberry Pi. I'm new to all this. Is there another language ( C++ maybe ) that I can use if Python is not available?
Thanks.
userHeadPic tedunn
2020-07-21 23:52:51 We are still testing the python library files on github. If you can, can you please describe the problem you encountered in more detail? userHeadPic 309330066
2020-07-20 18:26:33 Hi! Could you make measurements?there is a phyton script in the .zip file of the library. Im working on arduino, the values returned from the sensor doesn t seem to be congruent. Te PPB concentration goes from 60 to 125 with or with or with out the ozone generator ON. I left the sensor power up for 48hs for the firs time, the addres is correct, i try automatic and pasive mode...but no differences....I am missing something?? userHeadPic diegosarlinga
2020-05-11 10:25:56 Here only Arduino language library but nothing I found for python language:
https://github.com/DFRobot/DFRobot_OzoneSensor#credits
userHeadPic anonymous
2020-05-10 14:08:18 do you need this adapter?
https://wiki.dfrobot.com/Gravity__I2C_A ... U__DFR0553
The ADS1115_ReadVoltage.py script reads the voltages of the sensor
Where can I find the python script to read ozone in ppm instead?
