Forum >BNO055 - How To Get Linear Acceleration Values As Float Type
As i mentioned on the topic, I need to get linear accelaration values as float but library returns integer. I am using DF Robot Library with arduino nano. My code is below and the output is like on the picture, How can i get values as float ?
#include "DFRobot_BNO055.h" #include "Wire.h" typedef DFRobot_BNO055_IIC BNO; // ******** use abbreviations instead of full names ******** BNO bno(&Wire, 0x28); // input TwoWire interface and IIC address void printLastOperateStatus(BNO::eStatus_t eStatus) { switch(eStatus) { case BNO::eStatusOK: Serial.println("everything ok"); break; case BNO::eStatusErr: Serial.println("unknow error"); break; case BNO::eStatusErrDeviceNotDetect: Serial.println("device not detected"); break; case BNO::eStatusErrDeviceReadyTimeOut: Serial.println("device ready time out"); break; case BNO::eStatusErrDeviceStatus: Serial.println("device internal status error"); break; default: Serial.println("unknow status"); break; } } void setup() { // put your setup code here, to run once: Serial.begin(115200); bno.reset(); while(bno.begin() != BNO::eStatusOK) { Serial.println("bno begin faild"); printLastOperateStatus(bno.lastOperateStatus); delay(2000); } Serial.println("bno begin success"); } void loop() { // put your main code here, to run repeatedly: BNO::sAxisAnalog_t sLiaAnalog; sLiaAnalog = bno.getAxis(BNO::eAxisLia); // read linear acceleration Serial.print(" x: "); \ Serial.print(sLiaAnalog.x); Serial.print(" y: "); \ Serial.print(sLiaAnalog.y); Serial.print(" z: "); \ Serial.println(sLiaAnalog.z); }
