Forum >Help with RoMeo V2[R3] and 6V 40RPM 10kg-cm - DC Motor
userHead Account cancelled 2020-05-27 05:15:51 1313 Views2 Replies
Hi there
I have RoMeo V2[R3] board and I am trying to use the integrated 2 way DC motor driver circuit to drive 2x 6V 40RPM 10kg-cm - DC Motors
This is the code:
int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control
int M2 = 7; //M1 Direction Control
void setup(void){
Serial.begin(19200);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
void loop(void){
analogWrite (E1,a);
digitalWrite(M1,HIGH);
analogWrite (E2,b);
digitalWrite(M2,HIGH);
I connected 9v through the System & Motor power in port but nothing happens
I also made sure that the System & Motor power switch is on
What am i doing wrong.
The board works fine with all other sensors, just the DC motor bit.
