Forum >Connecting two Blunos
Bluno General Arduino
userHead nikolsidirop 2020-05-28 10:09:26 7494 Views9 Replies
I want to tranfer data from a Bluno Nano to a Bluno MEGA.
I have updated the firmware to 1.97 in both through the BlunoFWDownloader.
SBL_BleMega2560V1.97.bin for the Mega and SBL_BlunoV1.97 for the nano.
I have followed following link
https://wiki.dfrobot.com/Bluno_SKU_DFR0 ... n.EF.BC.89
The Bluno Nano works fine, but in the Bluno Mega after configuration I cannot upload the code. The uploading bar goes to 100% and sticks there, after a long time (more than 5 min) I get following error:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 2030 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 198 bytes (2%) of dynamic memory, leaving 7994 bytes for local variables. Maximum is 8192 bytes.
An error occurred while uploading the sketch
My code is
Code: Select all//Bluno_Receiver_AT+SETTING=DEFCENTRAL void setup() {  Serial.begin(115200); } void loop() {    while (Serial.available() > 0) {    Serial.println("available");    int inCommand = Serial.read();    Serial.println(inCommand);  } }
I tried to do what is suggested in this link but the .zip file does not exist.
https://www.dfrobot.com/forum/topic/1733
Is there any solution? Why is this happening only to the one of the Blunos?
2020-07-01 04:40:22 I did everything you suggested and managed to upload the script. Thank you very much!
The mistake was the power supply. I had to power the MEGA board through a usb port without serial connection, so not through a PC.
However, I noticed that it is possible to upload a sketch to the nano board, only if the MEGA is not powered (no connection).
In the interative project I build, the Nano will be placed in a moving part, thus it will be super inconvenient to programm everything through the Nano. I was wondering if it is possible to have it the other way around. To program the nano through the MEGA.
userHeadPic nikolsidirop
2020-06-15 03:31:46 I did the AT Commands as described and binded the MEGA MAC address in the nano bluno. I got an 'OK' as feedback in all the AT commands I inserted. The link LED in both blunos is on, but now I cannot upload nothing in both bluno nano and MEGA. The serial ports are proper selected.
Nano error:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe3
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Bluno Mega error:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
2020-06-08 12:33:20 I used UNO as a burner and followed the link. However the error led blinked two times in the beginning for a short time while running the burn bootloader. And if I try to upload a sketch to the Bluno ATMega 2560 the same error occurs.
Sketch uses 656 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
the selected serial port
does not exist or your board is not connected
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
2020-05-29 12:58:13 If I upload the blink example (if you mean that), I get
Sketch uses 1448 bytes (0%) of program storage space. Maximum is 253952 bytes.
avrdude: verification error, first mismatch at byte 0x0400
0x5c != 0x58
avrdude: verification error; content mismatch
