Forum >Troubleshooting Maqueen robot
RoboticsGeneral
userHead adrienne.donoghue 2020-07-02 19:23:49 3073 Views4 Replies
Hi there,
I'm trying to get my new Macqueen robot to work. I am using the sample code from your site through Microsoft MakeCode. The sample codes on this page worked for me a couple of days ago: https://wiki.dfrobot.com/micro_Maqueen_ ... _ROB0148-E
Here are the things I have checked:
Microbit is connected to computer (and working- will show LED lights on microbit)
Maqueen robot is turned on and has new batteries.
Program seems to download onto microbit okay e.g. some things work such as anything on Microbit LED interface and even LED r and LED l on Maqueen work and light up when programmed. )
However maqueen will not move-motor will not work (they were working with the same program 2 days ago)
RGB lights will not work (they were working with the same program 2 days ago)
Any ideas what's wrong?
2020-07-09 19:06:33 I already have the Maqueen extension open/available in Makecode extensions. userHeadPic adrienne.donoghue
2020-07-09 19:03:33 I don't understand what you mean? Can you be more specific?
The code worked the first time for both led and motors but no longer does
