Forum >2 Bluno Beetles--communication issues with simple code and serial
Bluno General Arduino
userHead Account cancelled 2020-07-02 13:09:05 2703 Views1 Replies
Can someone help me. I am trying to send mapped analog values from 0 to 100 from a master bluno beetle to a linked/paired slave bluno beetle. I want the slave to take the value and multiply it by a value and print the result to the serial monitor. It doesn't seem to work though.
I feel like its an issue with the bluno beetles using the serial communication and me trying to use the serial monitor at the same time but maybe not. Right now I get the value from the master beetle and it shows up on slave serial monitor but it never prints the values value to the screen or anything else.
Thank you,
//Master Code
int old_value; //Prior reading value from analogRead
Serial.begin(115200);
Serial.print("Simple Master Beetle Program--BLUETOOTH");
//Current code that takes and maps analog value from potentiometer and sends to slave device.
int mappedValue = map(analogRead(A0), 0, 1023, 0, 100);
if (abs(mappedValue - old_value) > 1) {
old_value = mappedValue; // save the changed value
Serial.println(mappedValue);
//Serial.write("");
//Serial.write(mappedValue);
delay(1000);
//Slave Code
int values = 10;
char com;
Serial.println("Simple Slave Beetle Program----BLUETOOTH");
while (Serial.available() > 0) {
com = Serial.read();
Serial.println("Yes");
delay(10);
Serial.println(com);
values = values * com;
Serial.print("Values is: ");
Serial.println(values);
