Forum >Gravity: UART Infrared CO2 Sensor (0-50000ppm) problem
TroubleshootingGravity
userHead kizzzane 2020-07-20 21:43:26 2568 Views6 Replies
After about 3-4 minutes the sensor becomes unresponsive every time. im using esp NodeMCU and software serial. the sensor work great for a couple minutes then stops responding. the NodeMCU does not freeze. the only way the sensor ill work again is if i unplug the power from the co2 sensor to restart it? Please help!!
2023-07-20 09:28:00
What error did it show?
2023-07-20 08:29:12
Was your problem ever solved?
userHeadPic Mark.Chivers
2020-07-25 13:43:23 its not the power supply. im using a programmable dc power supply at 5.2v. userHeadPic kizzzane
2020-07-22 08:55:36 I have 3 of these sensors and all 3 of them do the same thing. moving the delay helps it work a lot longer but in the end it still crashes? Im using esp8266 and software serial. any help would be greatly appreciated. I have sunk $300 dollars in the and they wont work userHeadPic kizzzane
2020-07-21 06:20:45 This code on your website is in error,
Code: Select all
* Infrared CO2 Sensor 0-50000ppm(Wide Range)
* The follow example is used to detect CO2 concentration.
* @author lg.gang([email protected])
* @version V1.0
* @date 2016-6-6
* GNU Lesser General Public License.
* See <http://www.gnu.org/licenses/> for details.
* All above must be included in any redistribution
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
unsigned char hexdata[9] = {0xFF,0x01,0x86,0x00,0x00,0x00,0x00,0x00,0x79}; //Read the gas density command /Don't change the order
Serial.begin(9600);
while (!Serial) {
mySerial.begin(9600);
mySerial.write(hexdata,9);
delay(500);
for(int i=0,j=0;i<9;i++)
if (mySerial.available()>0)
long hi,lo,CO2;
int ch=mySerial.read();
if(i==2){ hi=ch; } //High concentration
if(i==3){ lo=ch; } //Low concentration
if(i==8) {
CO2=hi*256+lo; //CO2 concentration
Serial.print("CO2 concentration: ");
Serial.print(CO2);
Serial.println("ppm");
it should be,
Code: Select all
* @version V1.0
* @date 2016-6-6
Serial.begin(9600);
while (!Serial) {
long hi,lo,CO2;
if(i==8) {
Serial.print(CO2);
delay(500);
2020-07-20 22:55:16 the problem might be in your sample code. i think the delay is in the wrong place? userHeadPic kizzzane
