Forum >DFPlayer - only returns -1 for myDFPlayer.read
userHead fastedtex 2020-09-10 21:18:32 2451 Views2 Replies
Serial.println(myDFPlayer.readEQ());
Serial.println(myDFPlayer.readFileCounts());
None of the myDFPlayer.read commands return anything other than -1
Any clue why?
2020-09-11 12:33:25 Serial.println(myDFPlayer.readEQ());
Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
Serial.println(myDFPlayer.readFileCountsInFolder(2)); //read file counts in folder SD:/02
Returned this:
EQ=NORMAL
-1
-1
-1
26
userHeadPic fastedtex
2020-09-11 12:06:48 #include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#include <IRremote.h>
# define code4 57375 //code from button left
# define code5 43095 //code from button right
# define code8 36975 //code from button OK
# define code7 26775 //code from button down
# define code6 39015 //code from button up
# define code9 25245 //code from button stop
# define code3 41565 //code from button power
# define code2 765 //code from button loop
# define code10 49725 //code from EQ
# define code11 45135 //code from 0
# define code12 31365 //code from 3
# define code13 23205 //code from 6
# define code14 21165 //code from 9
# define code15 6375 //doce from 2
# define code16 17085 //code from 7
# define code17 19125 //code from 8
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
int RECV_PIN = 9; // the pin where you connect the output pin of sensor
int thing = 4;
int SOUND = 1;
boolean isPlaying = false;
IRrecv irrecv(RECV_PIN);
decode_results results;
mySoftwareSerial.begin(9600);
Serial.begin(115200);
Serial.println();
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
irrecv.enableIRIn(); // Start the receiver
delay(100);
//----Set volume----
myDFPlayer.volume(10); //Set volume value (0~30).
// myDFPlayer.volumeUp(); //Volume Up
// myDFPlayer.volumeDown(); //Volume Down
//----Set different EQ----
myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
// myDFPlayer.EQ(DFPLAYER_EQ_POP);
// myDFPlayer.EQ(DFPLAYER_EQ_ROCK);
// myDFPlayer.EQ(DFPLAYER_EQ_JAZZ);
// myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);
// myDFPlayer.EQ(DFPLAYER_EQ_BASS);
//----Set device we use SD as default----
// myDFPlayer.outputDevice(DFPLAYER_DEVICE_U_DISK);
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
// myDFPlayer.outputDevice(DFPLAYER_DEVICE_AUX);
// myDFPlayer.outputDevice(DFPLAYER_DEVICE_SLEEP);
// myDFPlayer.outputDevice(DFPLAYER_DEVICE_FLASH);
//----Mp3 control----
// myDFPlayer.sleep(); //sleep
// myDFPlayer.reset(); //Reset the module
// myDFPlayer.enableDAC(); //Enable On-chip DAC
// myDFPlayer.disableDAC(); //Disable On-chip DAC
// myDFPlayer.outputSetting(true, 15); //output setting, enable the output and set the gain to 15
//----Mp3 play----
myDFPlayer.next(); //Play next mp3
delay(500);
// myDFPlayer.previous(); //Play previous mp3
// delay(1000);
// myDFPlayer.play(1); //Play the first mp3
// delay(1000);
// myDFPlayer.loop(1); //Loop the first mp3
// delay(1000);
// myDFPlayer.pause(); //pause the mp3
// delay(1000);
// myDFPlayer.start(); //start the mp3 from the pause
// delay(1000);
// myDFPlayer.playFolder(15, 4); //play specific mp3 in SD:/15/004.mp3; Folder Name(1~99); File Name(1~255)
// delay(1000);
// myDFPlayer.enableLoopAll(); //loop all mp3 files.
// delay(1000);
// myDFPlayer.disableLoopAll(); //stop loop all mp3 files.
// delay(1000);
// myDFPlayer.playMp3Folder(4); //play specific mp3 in SD:/MP3/0004.mp3; File Name(0~65535)
// delay(1000);
// myDFPlayer.advertise(3); //advertise specific mp3 in SD:/ADVERT/0003.mp3; File Name(0~65535)
// delay(1000);
// myDFPlayer.stopAdvertise(); //stop advertise
// delay(1000);
// myDFPlayer.playLargeFolder(2, 999); //play specific mp3 in SD:/02/004.mp3; Folder Name(1~10); File Name(1~1000)
// delay(1000);
// myDFPlayer.loopFolder(5); //loop all mp3 files in folder SD:/05.
// delay(1000);
// myDFPlayer.randomAll(); //Random play all the mp3.
// delay(1000);
// myDFPlayer.enableLoop(); //enable loop.
// delay(1000);
// myDFPlayer.disableLoop(); //disable loop.
// delay(1000);
isPlaying = true;
//----Read imformation----
// Serial.println(myDFPlayer.readState()); //read mp3 state
// Serial.println(myDFPlayer.readVolume()); //read current volume
// Serial.println(myDFPlayer.readEQ()); //read EQ setting
// Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
// Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
// Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read file counts in folder SD:/03
if (irrecv.decode(&results))
unsigned int remote = results.value;
Serial.println(remote);
delay(500);
switch(remote)
case code8:
if(isPlaying)
isPlaying = false;
}else
isPlaying = true;
break;
case code5:
myDFPlayer.next();
break;
case code6:
break;
case code7:
break;
case code4:
break;
case code2:
break;
case code9:
myDFPlayer.sleep();
break;
case code15:
myDFPlayer.loopFolder(2); //loop all mp3 files in folder SD:/05.
break;
case code16:
Serial.println("DEVICE=SD");
break;
case code17:
Serial.println("DEVICE=UDISK");
break;
case code10:
SOUND = 2;
Serial.println("EQ=ROCK");
break;
case code11:
SOUND = 1;
Serial.println("EQ=NORMAL");
// Serial.println(myDFPlayer.readFileCountsInFolder(2)); //read file counts in folder SD:/03
break;
case code12:
SOUND = 1;
Serial.println("EQ=POP");
break;
case code13:
SOUND = 1;
Serial.println("EQ=BASS");
break;
case code14:
SOUND = 1;
Serial.println("EQ=JAZZ");
break;
case code3:
break;
irrecv.resume(); // Receive the next value
if (myDFPlayer.available()) {
printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
break;
case WrongStack:
Serial.println(F("Stack Wrong!"));
break;
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
break;
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
break;
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
break;
case DFPlayerUSBInserted:
Serial.println("USB Inserted!");
break;
case DFPlayerUSBRemoved:
Serial.println("USB Removed!");
break;
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
break;
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
break;
case Sleeping:
Serial.println(F("Sleeping"));
break;
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
break;
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
break;
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
break;
case FileMismatch:
Serial.println(F("Cannot Find File"));
break;
case Advertise:
Serial.println(F("In Advertise"));
break;
default:
break;
break;
default:
break;
