Forum >Analog pH Meter Pro - RB-Dfr-639
Hello.
I'm having some issues with this probe. I seem to need to offset the readings by +.28...
When I short out the BNC connector on a v1.1 of ADC, I get voltage 1.99 & PH Value 6.97 - 6.98.
Is my ADC interface okay still? or does it need to be replaced?
Thank you
Thank you
2020-09-14 18:50:44 From your numerical point of view, it is normal. The ADC, power supply voltage, probe, transmitter, these will all cause errors, but the error has a range, if the error is large, it is unnormal. But your error is not big, in a reasonable range.
Please follow the wiki method to calibrate, set the intercept and slope to eliminate errors as much as possible.
Youyou
