Forum >VL53L0X SKU: SEN0245 water level detection
Hello
I would like to use this sensor to measure a water level (dirty and crystalline). With LiDar sensors of other references I have had difficulties because the measurement obtained is the bottom of the container. The sensor beam goes through the water surface, instead of reflecting.
I have seen an example here about a similar application: https://maker.pro/arduino/projects/how- ... ing-device
However, because I will be making a large purchase I would like to be sure of its operation.
Thank you.
Sebastian
Thank you.
Sebastian
2020-11-21 02:13:02 This sensor is used to measure distance. I think it cannot be used to measure water level. If you need to measure water level, you can use SEN0204 or KIT0139
347945801
