Pi Zero UPS HAT (SKU: DFR0528) not keeping system alive - basic connection questions
Anyone out there who really got the UPS HAT working?
Tried to use it on a Pi2 Model B, but it will not keep the power up after I intentionally unplug the PSU.
So the first basic question is:
How should the DFR0528 supply power to the Pi2? Via the GPIO connectors?
Because I can´t measure 5V at Pin 2 or 4 of the DFR0528 if unconnected (Pi2 disconnected, PSU disconnected, Lithium battery connected and fully charged).
Or how else?
Second question:
How should input voltage be supplied to the Pi2/DFR0528 composition?
Micro-USB of Pi2 or Micro-USB of DFR0528?
Third question:
If I connect the DFR0528 to the Pi2 (Pin1 to Pin1), and connect the PSU only to the Pi2, I am not able to reliably read the values of the battery with the script from the Wiki (https://wiki.dfrobot.com/UPS%20HAT%20fo ... %20DFR0528).
Most of the time, I´ll get a "[Errno 121] Remote I/O error" reading the bytes.
If I do connect the DFR0528 to the PSU, too, then reading the values works reliably.
BUT: If I remove the power cable from the Pi2 then (simulating a power drop, or lets say, dusk in a solar powered environment), it will encounter a hard power off. This is exactly what the HAT should avoid, right?
So any hints what I´m doing wrong here?
Sorry, but I couldn´t find the answer to my questions in the Wiki (maybe they´re there, but I cannot read between the lines well enough)
I´m a little lost here, so will be thankful for any hints
Also, the mentioned Wiki contains some confusing typos and errors - and I´m obviously not allowed to edit there. So whom to contact to ask to correct them?
Also, according to the description in https://wiki.dfrobot.com/UPS%20HAT%20fo ... %20DFR0528, the switching on and off should only work for firmware version/revision 1.1 - where the HAT I have has "V1.0" printed on it.
So, anyone interested in improving the documentation here a little?
My questions now are:
- what are the real differences between V1.0 and V1.1?
- what board do I have now? 1.0 or 1.1? How can I find out for sure?
- if V1.0 really has no possibility to switch 5V on and off, I hope the default is "on" then, because otherwise the HAT would be completely useless?
- how can I order an old revision 1.0 then?
My use case is the following:
Use a Pi zero to provide data from a solar power plant. Use the UPS HAT to make sure the Pi can shut down properly at sunset (power is cut off).
This use case cannot be fulfilled with the UPS HAT I currently have, as unfortunately, when the current returns, the HAT is again at state "5V off" (therefore: bad default). And no-one will go to the solar power plant every day and push that freaking button.
If you read my question again, it does say "Lithium battery connected and fully charged".
And the mentioned lithium battery I use is a 3.7V lithium battery, I could observe it getting charged, and I could read the values of the battery via GPIO as also mentioned above.
Any hints if we assume those preconditions are valid?
https://www.dfrobot.com/product-437.html
It has an interface that can be used to connect a 3.7V lithium battery and a lithium battery welding point. It cannot supply power by itself. Its USB interface can charge the lithium battery.
All the problems you are currently experiencing are due to not connecting the battery
