Forum >SEN0295 RP-C18.3-LT Thin Film Pressure Sensor
I am writing to ask about the combination application of RP-C18.3-LT Thin Film Pressure Sensor and Vibration Motor Flat Coin.
I would like to build a project with Vibration Motor Flat Coin and Thin Film Pressure Senso to construct a force feedback system as shown below.
Which type of Arduino board is needed and what will be the corresponding source code?
Could you show me the circuit like the photo below?
Thank you very much!
2021-01-05 18:33:05 There is no problem with the circuit diagram, and the code can be read by a simple analog voltage.
347945801
