Forum >DFRobot TCS3200 Color Sensor w/ Orangutan Microcontroller
3D PrintingGeneral
userHead denorro 2013-01-26 15:38:25 9433 Views5 Replies
I have been trying to get the tcs3200(https://wiki.dfrobot.com/TCS3200_Color_Sensor__SKU_SEN0101_) color sensor to give me back some meaningful values for some time now. I am using a pololu microcontroller so the code that comes with the sensor doesn't work for me like it would an Arduino. My micro has functions similar to the Arduino but I tried rewriting the arduino code to fit my micro but it still doesn't work. Can I set out pin on the color sensor as a digital input and read values from there or use some pulse function to read a value from it.
In my code i tried this routine:
1. Set s0-s3 as outputs just like the arduino code.
2. set s0 ad s1 both as high to configure 100% scaling.
3. set s2 and s3 as low to config. red filter.
4. set the out pin as an high input to hopefully get some value back from the pin. I also used a pulse() function
from my micro's library but it only give me a 1 or 0.
5. I also have the LED'S on through this whole process and turning off at the end and process starts over.
Here is some code I have written for it:
Code: Select all#include <pololu/orangutan.h> void blinkLED(int ms) // ms is the blinking time for LED for milli-seconds { set_digital_output(IO_B3,HIGH); delay(ms); set_digital_output(IO_B3,LOW); delay(ms); } void startLED() { set_digital_output(IO_B3,HIGH); } void stopLED() { set_digital_output(IO_B3,LOW); } void selectRed() // SELECT RED FILTER, ONLY LETS IN RED LIGHT { set_digital_output(IO_C1,LOW); set_digital_output(IO_D0,LOW); } void selectGreen() // SELECT GREEN FILTER, ONLY LETS IN GREEN LIGHT { set_digital_output(IO_C1,HIGH); set_digital_output(IO_D0,HIGH); } void selectBlue() // SELECT BLUE FILTER, ONLY LETS IN BLUE LIGHT { set_digital_output(IO_C1,LOW); set_digital_output(IO_D0,HIGH); } int main() { while(1) { startLED(); set_digital_output(IO_B4,HIGH); set_digital_output(IO_C0,HIGH); selectRed(); pulse_in_start(IO_D1,1); set_digital_input(IO_D1,PULL_UP_ENABLED); print(new_pulse(get_last_high_pulse(IO_D1))); delay(500); clear(); stopLED(); delay(500); } }
Here is a link to my micro's library and commands reference:
http://www.pololu.com/docs/0J20 and http://www.pololu.com/docs/0J18
COULD ANYONE GIVE SOME SOME HELP WITH THIS COLOR SENSOR?
2013-02-25 22:01:06 Yes, it is ok that you connect the sensor with the micro. I know that the surrounding light will affect the test result.  you can put it in a black box & turn on the blue ,red,green led as the light source(that time you don't need to turn on the led pin of the sensor).Maybe the result will be better. userHeadPic Phoebe
2013-02-22 23:29:35 Micro pins C0 and C1 connect  sensor's S0 and S1 are the pins on the color sensor to setup of the scale factor (in my case 2%)
Micro pin B3 is connected to the led pin  on the sensor
Micro pins D0 and D1 is connected to pin S2,S3 on the color sensor that I'm using to set the filters.
(r,g,b,clear filters)
micro pin D2 is the output pin from the color sensor that sends the data back to the micro.
The get_last_high_pulse returns the duration of the high pulse from that square wave and enclose it in pulse_to_microseconds to convert that time in microseconds otherwise it will give me the time in multiples of 0.04 microseconds.
userHeadPic denorro
2013-02-20 19:20:12 Hi, seems nothing wrong in or code. can you give more details about which pins of your pololu microcontroller connect to the sensors' pins? Such as "IO_C0" to pin ...? userHeadPic Phoebe
2013-02-19 21:11:26 Am I using this color sensor right? I measuring the duration of the output square wave that is outputted from the sensor. Using that duration I am calculating frequency. I am getting consistent values for objects that are very close. I would I go about measuring objects that aren't that far away but the surrounding light does have an effect on the square wave duration readings. How can I measure the surrounding light and use that to almost get the same values as when there was no light as when the object was very close?
PLEASE DO SHARE YOUR THOUGHTS! ALL ARE WELCOME!
Here is my code:
Code: Select all
//unsigned long sum = 0;
unsigned long red = 0;
unsigned long green = 0;
unsigned long blue = 0;
unsigned long Clear = 0;
set_digital_output(IO_C0,LOW);
set_digital_input(IO_D2,PULL_UP_ENABLED);
pulse_in_start((unsigned char[]){IO_D2},1);
while(1){
ledOn();
if(new_high_pulse(0)){
set_digital_output(IO_D0,HIGH); // clear filter
set_digital_output(IO_D1,HIGH); // clear filter
delay(10);
Clear = pulse_to_microseconds(get_last_high_pulse(0)); // get the length of pulse of clear
int clearFreq = (1 / (2 * (Clear * 0.000001)));  //converts the duration to microseconds and f = 1 / 2*T
set_digital_output(IO_D0,LOW); // RED FILTER
set_digital_output(IO_D1,LOW); // RED FILTER
delay(10);
red = pulse_to_microseconds(get_last_high_pulse(0)); // get the length of pulse of red
int redFreq = (1 / (2 * (red * 0.000001)));
set_digital_output(IO_D0,HIGH); // GREEN FILTER
set_digital_output(IO_D1,HIGH); // GREEN FILTER
delay(10);
green = pulse_to_microseconds(get_last_high_pulse(0));
int greenFreq = (1 / (2 * (green * 0.000001)));
set_digital_output(IO_D0,LOW); // BLUE FILTER
set_digital_output(IO_D1,HIGH); // BLUE FILTER
delay(10);
blue = pulse_to_microseconds(get_last_high_pulse(0));
int blueFreq = (1 / (2 * (blue * 0.000001)));
print("r:");
print_long(red);
lcd_goto_xy(8,0);
print("g:");
print_long(green);
lcd_goto_xy(0,1);
print("b:");
print_long(blue);
lcd_goto_xy(8,1);
print("c:");
print_long(Clear);
delay(2000);
clear();
//print("r:");
print_long(redFreq);
lcd_goto_xy(8,0);
//print("g:");
print_long(greenFreq);
lcd_goto_xy(0,1);
//print("b:");
print_long(blueFreq);
lcd_goto_xy(8,1);
//print("c:");
print_long(clearFreq);
delay(2000);
clear();
userHeadPic denorro
2013-01-28 21:21:17 Hi,
Try to capture the sensor input from the out pin using the interrupt IO pin of your pololu microcontroller!
The scaling you setting now runs very fast. I suggest to try it with a lower frequency when testing first.  ;)
Look forward to your response.
userHeadPic Lauren
