Forum >Vibration Sensor (DFR0027)
3D PrintingGeneral
userHead Account cancelled 2013-03-18 17:10:33 5745 Views1 Replies
Is anyone knowledgeable on this Vibration Sensor? I'm wondering if I can use this until without a board. Just want to connect 5v and have an LED turn on/off with the unit detecting motion. Also, what capabilities does the Input wire give (if using a board with coding)?
thanks,
Ron
2013-03-18 18:49:50 Hi
You mean you just want to use the vibration sensor to enable a led without a microcontroller? If is, maybe you need a audion to amplify the signal, made the audion works as a switch to enable the led.
userHeadPic Phoebe
