Forum >Turbidity sensor
Turbidity sensor
userHead Account cancelled 2021-01-25 10:58:49 778 Views1 Replies
I would like to use a Turbidity sensor SKU SEN0189 to measure in wastewater in flow. Can I use the sensor directely on the flow or I should use a flow cell?
2021-01-26 17:45:52 This sensor can be used directly in running water, but it should be noted that it is an optical sensor and has no special waterproof treatment. userHeadPic 347945801
