Forum >Gravity: Analog PH Sensor/Meter V2 problem
General Gravity
userHead Account cancelled 2021-02-21 04:15:09 2198 Views1 Replies
Hello, I am quite new to arduino but I've purchased a PH sensor from dfrobot. Set it all up, following the instructions on:
https://wiki.dfrobot.com/Gravity__Analog_pH_Sensor_Meter_Kit_V2_SKU_SEN0161-V2
I upload the code and go to serial monitor and read following (watch pictures). It seems like the first read is working but then I just get odd symbols as return. Is the code faulty or am I doing something wrong? appreuciate any inputs here!
2021-02-22 17:33:58 You need to check if the baud rate in the setup() function is the same as your serial monitor userHeadPic 347945801
