Forum >SHT30 (SEN0385) for high humidity conditions
userHead Account cancelled 2021-06-29 02:30:34 755 Views1 Replies
I would like to use the SHT30 sensor in high humidity conditions for continuous reading.
https://wiki.dfrobot.com/SHT30%20Digita ... %20SEN0330
Does anyone have an example of how to manage the heater? Should it be switched on permanently white in the high humidity environment or should it only be switched on for a short period before taking a reading?
Is there an algorithm to compensate for the increased temperature and lower humidity reading while the heater is on?
2021-09-28 18:36:32 I should express that I like this article so a ton and moreover using it in regular. I believe you would continue sharing better than average articles here.
cookie clicker
userHeadPic anonymous
