Forum >FIT0186 encoder
FIT0186 encoder
userHead daniel.brownell 2021-06-30 04:08:04 1046 Views1 Replies
I'm trying to get the built-in encoder working for the FIT0186.
https://wiki.dfrobot.com/12V_DC_Motor_2 ... __FIT0186_
The example wiki code doesn't work, and I've modified it as far as I can using sensible changes.
I'm plugging both Hall Sensor A and B outputs to the interrupts.
Currently, when I plug in the 12V, it triggers an interrupt, but then other than that initial pulse, no interrupts are triggerred.
The motor is moving as expected. Attaching my code. Has anyone got the encoder working?
const byte encoder0pinA = 2;
const byte encoder0pinB = 3;
volatile int posA;
volatile int posB;
int DIR1 = 8;
int PWM1 = 9;
Serial.begin(115200);
pinMode(DIR1, OUTPUT);
pinMode(PWM1, OUTPUT);
pinMode(encoder0pinA,INPUT);
pinMode(encoder0pinB,INPUT);
attachInterrupt(digitalPinToInterrupt(encoder0pinA), encoderA, RISING);
attachInterrupt(digitalPinToInterrupt(encoder0pinB), encoderB, RISING);
Serial.print("Pulse:");
Serial.println(posA);
Serial.println(posB);
noInterrupts();
posA = 0;
posB = 0;
interrupts();
delay(100);
int value;
digitalWrite(DIR1, HIGH);
for(value = 0 ; value <= 255; value += 5)
analogWrite(PWM1, value); //PWM Speed Control
delay(20);
delay(100);
for(value = 255 ; value >= 0; value -= 5)
delay(20);
delay(100);
digitalWrite(DIR1, LOW);
delay(20);
delay(100);
delay(20);
void encoderA()
posA++;
void encoderB()
posB++;
2021-07-11 05:39:18 I had Hall sensor GND and VCC backwards. Oops. userHeadPic daniel.brownell
