Forum >What is the correct file structure for the SD card on the dfplayer?
I am trying to use the example sketch from the Arduino IDE (GetStarted.ino). After discovering that the example sketch was written for an older version of the library and fixing the
I've found three different file structures to use on the SD card, but none of them work.
I am using a 32gB card formatted as FAT32, and the files are named "0001.mp3", "0002.mp3" and "0003.mp3".
From various sources on the df website and this forum, I have tried putting the files in the root, in a folder named "mp3" and in a folder named "01". None worked.
So, why the error: DFPlayerError:Card not found?
line, I have been trying to get past the error: DFPlayerError:Card not found.if (!myDFPlayer.begin(mySoftwareSerial,true,false)){
