Forum >Firebeetle M0: AVRDude error message after flashing
userHead Account cancelled 2021-12-16 08:56:32 688 Views0 Replies
I'm running Arduino IDE 1.8.13 with the dfrobot Firebeetle library 0.0.4.
After flashing a program I get the following error message from AVRDude:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: verification error, first mismatch at byte 0x9364
0x30 != 0x04
avrdude: verification error; content mismatch
The program I flashed works fine, but the error message is confusing.
Another problem I've already solved is the wrong or outdated link in the Firebeetle M0 Wiki for the Arduino boardmanager.
The correct link is:
http://download.dfrobot.top/firebeetle/ ... index.json
http://download.dfrobot.top/firebeetle/package_DFRobot_test_index.json
Please correct your Wiki, thanks.
o_lampe
