Forum >Recommendations for using a 15.6 4k display with LattePanda Alpha?
userHead Account cancelled 2022-02-18 03:43:46 2046 Views3 Replies
I'm building my first tablet using LPA as my motherboard of choice. I know on their website they mention there are some that can be used with a 30 pin connector. Do you have any suggestions/successes recently using this larger screen size natively? @@I could use an external controller board if needed, I'd rather put it all in one area to save space. @@Thanks!
2022-05-09 18:56:43
Maybe this display is suitable for you: https://www.dfrobot.com/product-2067.html
userHeadPic Youyou
2022-05-07 22:26:25
Hi there, here are some other larger displays on LattePanda Community for your reference.
http://www.lattepanda.com/topic-p25460.html
BTW, you can also use a TYPE-C display to save space.
userHeadPic Queenie.Le
