Forum >Sample Code Play Problems Need Help
Troubleshooting
userHead Account cancelled 2022-03-06 06:36:30 1094 Views2 Replies
I have installed the program "Sample Code - Play" on a Player Pro
When the player is powered up, there is a voice that says "Music". I only want the sounds I have uploaded and no voice.
How do I eliminate the voice.
Second, the sounds do not always play when the player is powered up. I hear the voice saying "Music" and then silence. This happens about 60% of the time when it powers up. The other 40% or so, after the voice, the sounds play.
How do I correct this?
2022-06-25 00:18:41
The module can close the voice prompt by AT command, the specific operations are as follows;1. Connect the module to the computer through TTL-USB conversion board;2. Use the serial port debugging software to connect the device to the serial port.3. Send AT command AT+PROMPT=OFF to turn OFF the PROMPT sound
userHeadPic Winster
