Forum >SEN0500 environmental sensor with 3.3V Pro Mini or Adfruit HUZZAH ESP32
ArduinoHow to select
userHead anonymous 2022-03-19 14:09:03 1884 Views1 Replies
Will this sensor work only with the FireBeetle ESP32 or will it work with ESP32 boards from Adafruit.com, for example, or even with boards without WiFi like a 3.3 V Pro Mini? If it will work with these other boards, do I need a different software library??
2022-04-18 19:00:05
It works with other ESP32 boards as well.   You don't need different software library to make it work.
userHeadPic R2D2C3PO
