Forum >How to change Lidar07 frame rate?
TroubleshootingArduino
userHead HUHONG 2022-04-15 06:34:47 655 Views6 Replies
I bought DFrobot's Lidar07 last month. After reading the datasheet, I found that the frame rate can be adjusted. I also used the arduino to measure  that  the update speed was  45ms, but the specification says that it can reach 500hz. How to send commands through arduino to get faster frame rate? Thanks
2022-04-16 11:57:20
Ground penetrating radar systems have a sampling rate setting, to determine the number of data samples captured per second. Higher sampling rate == higher data density, larger storage requirements, increased real-time computational requirements. So does our ultrasonic pulse echo system. I presume that any other similar reflection-based technology (radar, lidar, sonar, seismic, etc.) would use a similar model.
userHeadPic williamjon
2022-04-15 18:37:32
I am afraid that we don't have that Lidar model.  Do you have a link to that product?
userHeadPic R2D2C3PO
HUHONG wrote:
2022-04-21 19:35:09
HUHONG wrote:
2022-04-21 19:35:58
2022-04-15 07:45:37
The model is LIDAR07-100W-B,thanks
userHeadPic HUHONG
2022-04-15 07:14:48
Please specify the model, and it will be even better if you can provide the sku.
