Forum >How to fix the Gravity Analog pH Sensor?
TroubleshootingGravity
userHead Rojen VincentMedino 2022-05-15 20:27:40 1573 Views2 Replies
Good day everyone, How to fix the Gravity Analog pH Sensor  the output pH reading is always at 15.45 pH.
2022-05-16 08:00:13
Only when the transmitter board output 0V can it prints pH 15.45 on the serial monitor.
Please check whether the transmitter board gets the suitable supply voltage range, that is, 3.3~5V.
Then short circuit the BNC input pin, the pH value on the serial monitor should be about 7.0. If not, please contact techsupport@dfrobot.com for further help.
userHeadPic Youyou
2022-05-15 20:33:21
userHeadPic Rojen VincentMedino
