Forum >Code Issue FireBeetle ESP32-E & Beetle ESP32-C3
userHead AlexanderWoo 2022-05-20 04:55:54 1949 Views5 Replies
My code LS_Clone_ESP32 works perfectly on the FireBeetle Board ESP32-E, but when I try to put the same code onto the Beetle ESP32-C3
it doesn't transmit the BLE, in-fact I cant see any BLE from the device
https://github.com/wooby6/Lovense-Edge-clone-esp32/blob/main/LS_Clone_ESP32/LS_Clone_ESP32.ino
(edit the hidden hyperlink isn't working)
Comparing my BLE code to the BLE examples given, I cannot see any major differences
changing the pins of course (on line 53-27) to:
const int MA_PWM=0;
const int MA_DIR=1;
const int MB_PWM=4;
const int MB_DIR=5;
I don't use pins 6 or 2 as they are outputting to my motor driver immediately on boot, not sure why I'm getting 3.2v across those
Are they purposely set high on boot or is my board faulty?
& yes I have to GND pin 9 to upload anything,
on a related note connecting a factory fresh Beetle ESP32-C3 to my win 10 pc caused it to make a constant device disconnect sound
(I bought more than one so I can still test this bug)
the BLE examples on the wiki, work as intended
2022-05-23 05:54:51
Ok figured it out its incomparable with the DFrobot_MAX17043
userHeadPic AlexanderWoo
2022-05-23 04:18:37
ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)
Saved PC:0x4038187e
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x438
load:0x403ce000,len:0x90c
load:0x403d0000,len:0x2358
SHA-256 comparison failed:
Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9
Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19
Attempting to boot anyway...
entry 0x403ce000
[   180][E][Wire.cpp:319] beginTransmission(): could not acquire lock
[   180][E][esp32-hal-i2c.c:142] i2cWrite(): could not acquire lock
This Forums formatting is terrible & not having the ability to edit my replies is worse
2022-05-23 04:15:25
Ok I found some new info by setting it to verbose error modeBuild:Feb  7 2021rst:0x3 (RTC_SW_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)Saved PC:0x4038187eSPIWP:0xeemode:DIO, clock div:1load:0x3fcd6100,len:0x438load:0x403ce000,len:0x90cload:0x403d0000,len:0x2358SHA-256 comparison failed:Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19Attempting to boot anyway...entry 0x403ce000[   180][E][Wire.cpp:319] beginTransmission(): could not acquire lock[   180][E][esp32-hal-i2c.c:142] i2cWrite(): could not acquire lockESP-ROM:esp32c3-api1-20210207
