Forum >Fan On CM4 IoT Router Carrier Board Mini Acrylic Case
General Easy IoT
userHead JohnMinson 2022-05-28 04:46:46 1745 Views1 Replies
Can you mount a fan directly over the heat sink on the CM4 IoT Router Carrier Board Mini Acrylic Case ?
2023-04-22 02:56:09
Hi JohnMinson! I just did that with a noctua NF-A4x10. But i didn't use screws, used nylon clamps instead (did not look beautiful, but do the work).
userHeadPic viniciuspaes
